Jetting help needed on piped '01 Banshee
Old Nov 28, 2000 | 01:03 PM
v6power87's Avatar
Rode this weekend at Sand Lake and found I have a slight problem after installing FMF fatty pipes, K&N filter in airbox without lid, 290 main, 30 pilot, needle in stock position. The machine runs great in all areas exept from a launch in 2nd gear. When you drop the clutch in 2nd it will not bog- but take a second or two before coming up on the pipe and by then the other guy has me by a quad length. What would cause this? Pilot jet too big? Btw, my air screws are at 1 1/2 turns out.
Thanks. Dan
Old Nov 28, 2000 | 06:00 PM
mgrigsby22's Avatar
I have the exact same mods as you on my 99 banshee except I run the airbox on with holes drilled in the airbox lid. The only difference I didn't do is change the pilot jets from 25 to 30 and adjust the screws. It seems pretty dead in low rpms...should I bump up the pilot jet to a 30 for the bottom end? Should I also adjust the screws?
99 banshee fmf fatty pipes, power core 2 silencers, k&n filter with precharger, modified airbox lid, yellow maier racing fenders, blue shockwears
www.geocities.com/mgrigsby21
Old Nov 28, 2000 | 09:34 PM
rawze's Avatar
do a plug check to see if it's fat or lean and adjust air screws to dial it in-if you need help with this i know a great site on carb tuning. email me and i'll send it to you
rick
Old Nov 29, 2000 | 02:19 AM
v6power87's Avatar
Well.... I did a little research today and found maybe if I drop a tooth on the countershaft sprocket my problem will be fixed. Everyone I talked to said that my jetting and carb tuning is right on.
Dan
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Bm400ex
Jun 22, 2015 09:16 AM
Timjunior
Ask the Editor
May 28, 2015 01:09 PM
blaze_master
May 26, 2015 11:18 AM
B4NSH333
May 26, 2015 06:55 AM
