My Mojave is in Danger!!!
The mojave engine has more potential thanks to 4 valves. You need to help it flow more air and fuel thru those extra valves. Get a good exhaust, I have had supertrapp and white bro on my mojave and the white bro was superior. Switch to a 13 tooth front sproket as thats pretty cheap, get some good sticky tires and let it get more air, I use twin air as it filters dirt better than K&N, but If your after horsepower to win I'd use a fresh K&N (they are never as good-as-new after cleaning) or a very thin foam filter. You can also cut the snorkel off or drill large holes in it but there again it increases potential to suck dirt. Dont waste money on a jet kit, simply buy a few jets and youll save some money. The above mentioned items will beat a 300, but you mentioned cams and not knowing anything about the competitions grind, you may also have to add some cams, you may first try a good valve job and a little light porting work. If you add the white bro pipe you will probably want to eliminate the factory rev limit.
The dual-overhead cams help the Mojave rev faster compared to a single cam. I have ridden a 300ex and a 400ex and I can tell you I will never go back to a single cam because they rev so much slower, that it the 300 and 400's downfall. There is no upgrade that can replace dual overhead cams.
#15
Elkaholic
09-06-2015 02:44 PM
Mojave250A
07-11-2015 10:38 AM
