Stuck bolt, stripped, and stripped again, cut, help cant get it out
Old Jan 1, 2001 | 04:49 PM
  #21
Holyman's Avatar
I think the vise grips would work
Old Jan 2, 2001 | 11:34 PM
  #22
Javahere's Avatar
I'm not sure how big the head of the bolt is, but if you have access to a welder you take a bolt with the thread diameter about 2/3 to a 1/2 the size of the head of the striped one.Put the bolt on top of the striped one with the threads on top of the head and put 2 or 3 little tack welds around the bottom of the threads connecting it to the bolt.Just put a wrench on the new bolt you just welded to the striped one should come out.Good luck
Java
2000 Kodiak
Old Jan 6, 2001 | 12:08 AM
  #23
joelpolaris's Avatar
This may sound like a dumb question, but is the bolt maybe a reverse thread? If not, here's a trick that may work. Carefully heat the bolt, then quench with cold water and repeat a few times. This has worked for me on some very stubborn bolts. ALSO, spray some liquid wrench on the bolt each time before heating. The heat will draw the oil into the threads. Those vise grips rule!!! Use them if you can.
Good luck!
Old Jan 6, 2001 | 12:37 AM
  #24
rmx251's Avatar
So much help for a simple answer. Sell the little bike and get a kx500.
Or try some Easy-Outs. They have always worked for me, just remember to use the biggest one you have.
Joe454
Nov 20, 2020 01:19 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
tysonbully
Sep 28, 2015 02:30 AM
Jackg17
Sep 26, 2015 09:30 PM
