01 Sportsman speedometer
Old Sep 24, 2013 | 09:02 PM
SwampSteve's Avatar
Default 01 Sportsman speedometer
I was wondering if it's possible to replace the speedometer on my 2001 Sportsman with one from a later model bike? My speedometer has not worked in years. I like the shape of the head light and pod on the later models.
Old Sep 24, 2013 | 09:27 PM
2001 and 2002 models were the same,2003 was the start on the newer style speedos. Main problem wold be the wiring harness and connectors of course are different.
Old Sep 24, 2013 | 10:00 PM
SwampSteve's Avatar
I was thinking about changing the whole pod and headlight. It doesn't mater to me if the speedometer works. Will my fan and 4wd work without a speedometer? I read that it wouldn't.
Old Sep 24, 2013 | 10:02 PM
SwampSteve's Avatar
I know the speedometers are are smaller on the 2001 so I wouldn't be able to use it in a letter model pod.
Old Sep 24, 2013 | 10:27 PM
atv-wheeler's Avatar
I think what you are planning would be a quite expensive or a very complicated upgrade. Have you tried considering getting a aftermarket gauge or a new replacement gauge instead of swapping it with other model?
Old Sep 25, 2013 | 09:41 AM
TLC's Avatar
TLC
If your speedo does not work but you still have awd working then its your wheel sensor (Hall Efect) that's the problem.
The speedo are the same from 1998-2002 after that some wiring harness connections would have to be changed, plus the newer ones may have options your ATV is not set up for like gas gage and Tachometer.
My speedo has not worked for 3 years due to a bad $60 wheel sensor but the speedo just does not have important info I need. Only my hour meter and speedo lights work.
Old Sep 25, 2013 | 02:32 PM
SwampSteve's Avatar
Yep mine does the same thing and I want to say that I changed that sensor years ago when it was new and it still didn't work. I'm pretty sure those speedometers on the old bikes are notorious for going bad. I was just wanting to change the whole head light pod out. I figured I could splice in a new harness and get some of the stuff on a newer speedometer to work. Is the all wheel drive affected by the speedometer?
Jmuddin284
Jan 19, 2026 07:16 AM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
79hugger
Aug 30, 2015 02:21 PM
400H0
10
Aug 20, 2015 07:34 PM
