Has anyone tried Dial-a-jet?
#15
#16
Another product in the same category is Vari-Flow. This system uses air pressure changes in the carb, to adjust the gas level in the bowl. Therefore changing the mixture richer or leaner. Their system, starts out rich, and engine vacuum pulls down leaner, based on a adjustment ****. I'm familair with it in the snowmobile industry, and it has good reviews.
link to Vari-Flow, ie Holtzman Engineering
#17
Once your carb is jetted properly, the Dial-AJet does the rest. No more carb disassembly for mods. Just a note-when installing dial a jet, it's a good time to check your float level and set it properly. This adjustment is often overlooked. As an added bonus, after installation of the DAJ, the hose from the bottom of your float bowl does double duty as a float level checker without carb disassembly. The product is simple to install and works on simple principles. Don't be afraid to put one on. I have to admit I was skeptical at first and offered to install one on my buddy's Wolverine just to see how it worked. I did that one and have done mine and another buddy's. These buddys are NOT gearheads and they gave positive reports on the performance and driveability provided by the Dial-A-Jet. See www.thunderproducts.com
