banshee shifting problems
Old 04-09-2000, 02:07 PM
notfastenough's Avatar
I know a Banshee never shifts good anyways but it is worse now I already have a shift star mod but what I have now is under a full throttle drag race scenario I can not get my banshee to shift to third gear worth a sh-t sometimes it evens pops into a neutral position what areas should I start with first.
97 banshee 350cc ported by JD Racing
Old 04-09-2000, 07:01 PM
THEXOTIC1's Avatar
the shift forks are worn and also the cam could be worn change your oil alot and this should never happen
Old 04-09-2000, 07:02 PM
THEXOTIC1's Avatar
3rd gear is the most abused gear on any maual bike always check that gear before buying a bike
Old 04-09-2000, 08:44 PM
Veeshman's Avatar
I would say that the previous owner, or you, do what is called a speed shift, in that you shift under full throttle without the clutch and without letting the RPM's come down on the motor. That is fine, but it is murder on a transmission. I just did a tranny in a blaster with the same problem. (I work in a bike shop on the side). What happens is the dog ears on the 3/4 combination gear get rounded off, hence it won't stay in gear. So then what people do is use the shift lever to "hold it in gear" which completey ruins the forks, which adds metal to the oil, which just makes for more problems. Anyways, I would recommend tearing the motor down, taking out the tranny and take the gears off of the shafts, what you will find is what I have described, the ears will be rounded and that is the result of tranny abuse by the operator. This is not cheap, since tranny gears run about $800 for a complete set. I would take a close look at all of the gears or take it to somebody who knows what they are doing. It is not cheap, but your problme will only get worse, eventually the problem will "spread", fix it know when the damage is at a minimum!! later
Veeshman
Old 04-10-2000, 10:15 AM
sAyIt_fmf's Avatar
Hmmmmm....One of the posts up top mention that the cam could be the problem?
I change the cam in my banshee after every ride.
hehehe
Cole Hadden
08-24-2020 11:11 PM
KimSJoh
14
07-18-2015 07:20 PM
Dirtbikemike1
07-11-2015 03:36 PM
cSchwartz
07-09-2015 02:40 PM
07-07-2015 11:00 PM
Quick Reply: banshee shifting problems
