Engine removal 2000 Xplorer
Hey guys. I need to pull the engine out of my Xplorer. Do the front fenders and fuel tank have to come off to do this? Apparent piston breakage
, but I want to go thru the bottom end as well. I'm hoping I can wiggle it out the side without having to tear the whole front of the machine apart. Just asking, as the manual says to remove fuel tank.........
Brian
![](http://www.polarisatvforums.com/forums/images/smilies/puppy_dog_eyes.gif)
Brian
Brian
Brian
Took everybody's advise and it worked well taking the fenders and tank off. Only things original on my 400 now are my counterbalance and case halves. Had a broken piston and a very worn bore (.023 clearance. Really). Bought this thing (well used it turns out) this past spring. Mr Ritter did my cylinder (+.040) and built me a crank. I put all new bearings in. Just got it running tonight (idled a couple minutes without a clutch on it) and am pleased with how quiet it runs. My first two stroke rebuild. Yay. Machine is still naked as I have to run it a bit more and check again for leaks and what not.
Brian
Brian
