1996 polaris sportsman 500 help
Old Aug 7, 2012 | 09:42 PM
frankehvac's Avatar
Default 1996 polaris sportsman 500 help
After 3 long months my mechanic ate about a grand in labor my quad still doesn't run right. The problem is the atv will not go over 30 mph and is real slow to get there. If I pin the throttle in nuetral the wheeler will rev up maybe 60% and then after about 5 secounds it will slowly rev higher to what sounds like 100%. When driving it doesn't seem to get past that 60% point. My mechanic checked all the electical,carb ,cam top end of motor. Tonight i did find that the pipe entering the mufffler was cracked pretty bad so i did tack it back together. My mech also put a new air box in it. I must also say the problem is not constant. Today I was doing 55 mph and I slowed down and turned a corner and the machine started acting up. i have found similar posts on here but noone gives what the problem was. please help thanks frankehvac
Old Aug 8, 2012 | 06:19 AM
TLC's Avatar
TLC
Check for worn buttons in the clutches. Cheap parts that will slow you right down. I think the drive clutch has buttons Part#5431936 and the secondary has #5438123 .
Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Aug 8, 2012 | 06:29 AM
frankehvac's Avatar
is it normal to have the unit rev up slowly like i said also if the buttons are bad would the problem be constant my prob comes and goes
Old Aug 8, 2012 | 06:54 AM
TLC's Avatar
TLC
Read this post does it sound the same?, "Old Polaris Tech" is a retired Polaris Dealer shop mechanic.
http://forums.atvconnection.com/pola...end-power.html
Ooops sorry I did not notice its was your post also. LOL
Anyways if you use the seach option on this site like I did, and use "Buttons" as a subject, it seem that that could be your problem.
Old Aug 8, 2012 | 07:09 AM
TLC's Avatar
TLC
Here is another one where he did every thing and it did turn out to be the buttons.
http://forums.atvconnection.com/pola...sportsman.html
Old Aug 10, 2012 | 06:29 PM
frankehvac's Avatar
my mech ordered the buttons so my fingers are crossed
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
