Couple Questions Regarding my New Polaris 250
Old Sep 3, 2012 | 05:41 PM
ShelbyGT660's Avatar
So should I tear apart the engine then? Check ring gap? What would you do?
Old Sep 3, 2012 | 05:55 PM
I would pull the cylinder and remove the piston. You might be able to tell quickly if the piston has broken a skirt,seizure, score marks,etc. If piston shows no visible damage,just pull the rings off,install piston in bottom of cylinder and check clearance between the piston and cylinder with piston skirt at bottom of cylinder .Simple feeler guage will work. If you have .004 clearance or over, then it's time for a bore job. OPT
toonces
Oct 16, 2019 12:11 PM
green giant
Jul 13, 2017 12:07 PM
D-Hagz
Jul 4, 2015 02:19 AM
Shifts
Jul 3, 2015 07:59 AM
Nowinsky94
Technical and How-To Articles
May 27, 2015 07:29 PM
