starter
Check that you have voltage on the other solenoid post when you hit the starter. If you have 12 volts to the starter side,possibly a bad starter and/ or starter bendix.You can also jump the posts with a screw driver to see if the starter is ok. Starter's located on the bottom of the engine.Cheap place here to get starters if needed. Plus look at the manual link I listed about the starter and bendix.DB Electrical - 250 Plus for other parts,Cheap Cycle Parts usually has the cheapest oem parts. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
