2006 polaris sportsman 500 x2
Forgive my ignorance, but now when I engage the accelerator, in reverse or high forward, it jerks into gear. then proceeds to go. but makes clink sound when begins to move after having to give more gas than usual (it seems). Not always, but sometimes. Kind of like bad u-joint sounds on a car. It's not too bad yet, but worried if I keep riding it I may ruin something that costs lots more then if I fix or check something now. Please help me. What do I check first, and then next? and so on?
Just jack up the rear end,have in neutral and turn the rear tires back and forth. You should be able to tell real quick if it's a sloppy cv joint in the rear drive shafts or worn prop shaft u joints leading to the front diff.If you eliminate any cv or u joint slack,could be as simple as a glazed belt jerking on the clutches.
Ok, there is play moving wheels back and forth, no bad sounding noises, but certainly play. Is that a bad thing then? should I just bring it in or can I just keep riding it? If it is or were merely a glazed belt, how is that fixed? simply replaced, or just keep using it anyway? And what would have caused this play in the wheels anyway? how do u-joints and/or cv joints go bad?
bzdok1234
30
02-23-2016 01:55 PM
