2009 550 / 850 Transmission Interchangeability
Hi everyone, my first post from Albany, Western Australia -
Pretty flat over this way, the highest mountain we have in WA is a whole 1099m, so we mainly have bush, dune and coastal riding areas. Because of the low population to land mass in WA, you do not have the pressure of a lot of riders in the same area.
Question:
I have a 2008 500 ho and recently purchased a well used 2009 550 eps with a broken transmission ( bearing and silent chain broken), been looking at complete used transmissions from the US on ebay.
I have been reading that I can use transmission (1332786)from other years and from the 850, just wondering if this is correct?
Thank's in advance for your help.
Dennis
Question:
Dennis
Can't say that it would bolt up without any problems as there may be changes in the mounting,but I've seen stranger things than this people have been able to do. The 2009 550 and 850 did use the same gear case so it kind of stands to reason you possibly could get a different year model gear case that would mount up.
Usage : 1332473 GEARCASE
Year Product Model Assembly
2009 ATV SPORTSMAN XP 550 DRIVE TRAIN, MAIN GEARCASE - A09ZN55AL/AQ/AS/AT/AX (49ATVGEARCASE09SPXP550)
2009 ATV SPORTSMAN XP 550 INTL DRIVE TRAIN, MAIN GEARCASE - A09ZN55FX (49ATVGEARCASE09SPXP550)
2009 ATV SPORTSMAN XP 850 DRIVE TRAIN, MAIN GEARCASE - A09ZN85/8X ALL OPTIONS (49ATVGEARCASE09SPXP550)
2009 ATV SPORTSMAN XP EPS 550 DRIVE TRAIN, MAIN GEARCASE - A09ZX55AC/AL/AQ/AS/AX (49ATVGEARCASE09SPXP550)
2009 ATV SPORTSMAN XP EPS 850 DRIVE TRAIN, MAIN GEARCASE - A09ZX85/8X ALL OPTIONS (49ATVGEARCASE09SPXP550)
2009 ATV SPORTSMAN XP 550 DRIVE TRAIN, MAIN GEARCASE INTERNALS - A09ZN55AL/AQ/AS/AT/AX (49ATVTRANSINTL09SPXP850)
2009 ATV SPORTSMAN XP 550 INTL DRIVE TRAIN, MAIN GEARCASE INTERNALS - A09ZN55FX (49ATVTRANSINTL09SPXP850)
2009 ATV SPORTSMAN XP 850 DRIVE TRAIN, MAIN GEARCASE INTERNALS - A09ZN85/8X ALL OPTIONS (49ATVTRANSINTL09SPXP850)
2009 ATV SPORTSMAN XP EPS 550 DRIVE TRAIN, MAIN GEARCASE INTERNALS - A09ZX55AC/AL/AQ/AS/AX (49ATVTRANSINTL09SPXP850)
2009 ATV SPORTSMAN XP EPS 850 DRIVE TRAIN, MAIN GEARCASE INTERNALS - A09ZX85/8X ALL OPTIONS (49ATVTRANSINTL09SPXP850)
2009 ATV SPORTSMAN XP 550 DRIVE TRAIN, MAIN GEARCASE SHIFT FORKS - A09ZN55AL/AQ/AS/AT/AX (49ATVSHIFT09SPXP850)
2009 ATV SPORTSMAN XP 550 INTL DRIVE TRAIN, MAIN GEARCASE SHIFT FORKS - A09ZN55FX (49ATVSHIFT09SPXP850)
2009 ATV SPORTSMAN XP 850 DRIVE TRAIN, MAIN GEARCASE SHIFT FORKS - A09ZN85/8X ALL OPTIONS (49ATVSHIFT09SPXP850)
2009 ATV SPORTSMAN XP EPS 550 DRIVE TRAIN, MAIN GEARCASE SHIFT FORKS - A09ZX55AC/AL/AQ/AS/AX (49ATVSHIFT09SPXP850)
2009 ATV SPORTSMAN XP EPS 850 DRIVE TRAIN, MAIN GEARCASE SHIFT FORKS - A09ZX85/8X ALL OPTIONS (49ATVSHIFT09SPXP850)
[QUOTE=old polaris tech;3328949]Can't say that it would bolt up without any problems as there may be changes in the mounting,but I've seen stranger things than this people have been able to do. The 2009 550 and 850 did use the same gear case so it kind of stands to reason you possibly could get a different year model gear case that would mount up.
Thank you for that, I can see a couple of cups of coffee and bit of reading coming up tonight.
skeeterbilt
11
03-29-2016 01:07 PM
