1995 sportsman 400 dies in gear
Old 07-05-2016, 11:09 AM
snow2dirt's Avatar
Default 1995 sportsman 400 dies in gear
Intermittent issue while shifting in forward gear, the engine stalls. Will start in reverse. I have disconnected various switches (etc, override) and this does not help. Only after moving the shifter back and forth does the engine restart in forward or neutral gear. I suspect the gear switch to be faulty, help appreciated
Old 07-05-2016, 11:40 AM
Did you disconnect the black wire from the reverse limiter module located behind the oil tank? Normally this takes care of any dying in reverse or limiting in forward as some have done also by eliminating the limiter entirely.This way you can have full speed in reverse without even having to push the over ride button.
Old 07-07-2016, 09:55 AM
snow2dirt's Avatar
Thank you for the reply, I will try that in august when I get to my atv at my fishing camp
Old 08-18-2016, 03:52 PM
snow2dirt's Avatar
Your suggestion to disconnect the speed limiter seems to have done the job, thank you. Now the question is Do I replace the speed limiter module? Is it worth it what does it do exactly?
Old 08-18-2016, 04:18 PM
Don't replace this module,it's something that can/will fail again! Just a safety device that Polaris installed so people would have to push a button to have full power in reverse. Problem is that all of these fail. Some would die when placed in reverse,some would die or limit in forward range when they shorted out. Now you can have full power in reverse without having to mess with the over ride button.
chrisarvor
1) Engine problems..
03-31-2016 01:41 AM
Timbo2500
03-15-2016 10:30 AM
rottwolf
08-21-2000 12:08 AM
big-un
01-19-2000 01:17 PM
ChevyWeatherman
11-09-1999 11:13 PM
Quick Reply: 1995 sportsman 400 dies in gear
