Clutch Puller Thread Size
Old Dec 20, 2016 | 08:09 PM
ajax33's Avatar
Default Clutch Puller Thread Size
What is the thread diameter and thread pitch of the drive clutch puller bolt required to remove a Chinese-made drive clutch from 2000 Polaris Magnum 500 non-EBS ATV?
I purchased one of these Chinese-made clutches from Ebay seller named 'partsangel' for $174.
Please referenced this link: http://www.ebay.com/itm/162130874410?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The clutch is sold as Replacement for OEM Part Number 1321976, non EBS.
The problem is that the standard 3/4 inch dia 16 TPI Polaris puller tool will not fit into the Chinese-made clutch. The threads are completely different.
Old Dec 21, 2016 | 08:50 AM
Will probably be metric as that's all the Chinese use,but what size,could be 18,19mm? Only thing I can say is if you buy the clutch take it to a good hardware store and match the threads up before you ever install it..
Old Dec 6, 2023 | 05:46 PM
fred644413's Avatar
Default I have the same problem
Just wondering if you found out the thread size for the Chinese made clutch
Please referenced this link: Primary Drive Clutch For 1999-2003 2002 2001 2000 Polaris Magnum 500 | eBay
mykol040
May 7, 2013 04:44 PM
riddlebox_420
Sep 15, 2012 09:58 PM
94-400l
Oct 6, 2008 11:59 AM
RdrD
Jan 20, 2000 04:05 PM
