Rearend slipping on 325 magnum
Old Oct 9, 2018 | 03:41 PM
robs trailboss's Avatar
Default Rearend slipping on 325 magnum
my bike will not move under its own power when I put it in gear I can push it the drive shaft does not move but it makes a clicking type of sound . I jacked it up and turned the wheels while it was in gear it made the sound and looking down on the prop shaft coupling so I could see he grease nipple it did not move. I took the rear axle assembly off and the connections between the coupling and the pinion shaft seemed to be in good shape I then split the rear housing and looked at the gears . At this point I should tell you I don't have a clue what I am doing. So I took some pictures and hope someone can tell me if they are worn out parts
Old Oct 9, 2018 | 05:18 PM
It seems like the ring gear is slipping on the axle
Old Nov 9, 2018 | 03:36 PM
Has anyone ever welded the ring gear and rear axle on the old solid axle machines?
Oldsman67330
Jul 8, 2011 07:40 AM
dwci97
May 16, 2005 12:43 PM
IndyStorm
Apr 21, 2001 10:56 PM
Trauma
Oct 21, 1999 08:31 PM
