Shifter cable stretching?
Old Mar 17, 2020 | 05:39 PM
Protodog's Avatar
Default Shifter cable stretching?
My 2004 Ranger 500 has about 240 hours on it. Last month I found that it would not go into reverse. I fixed that with a simple adjustment to the shifter cable - I needed to move the retaining nut near the shifter arm about a half inch. It shifted fine for about 2 weeks and then had the same problem. This time, there wasn't enough thread left to adjust the cable. For a short term fix, I moved the cable up to another hole on the shifter arm, but it's clear that the second hole was not meant as a shifter cable mount. (The hole is a different size and shape than the original mounting hole.) Once again, it is working. So... here is my question. What is more likely - that the shifter cable is stretching, or that there is slippage inside the transmission such that the arm is pivoting forward?
Any insights from members with experience would be most appreciated; I would have no trouble replacing the cable), but would never trust myself to rebuild the transmission! .
Roxanne
Oct 14, 2018 07:51 PM
Roxanne
Oct 14, 2018 07:48 PM
Cancat
Mar 2, 2003 12:44 AM
barkbiterds
Jan 27, 2003 07:03 PM
Rob4092
Feb 20, 2001 11:25 PM
