Need Help With Clutch
Old Jun 19, 2003 | 08:47 PM
vig's Avatar
vig
Default Need Help With Clutch
I had the same problem with my scrambler secondary, Tried a puller and everything. If you have gotten water in the clutches it will rust on the shaft. i took the machine down to my local dealer and they came out and removed the clutch for free. It only took 2 min. I think they said they usually charge 10 dollars. before you put it back on make sure you use some anti sieze on the shaft. Good luck
Old Jun 19, 2003 | 10:02 PM
jcrum20's Avatar
Hey thanks. I think that is probably what happened because I have had water in there several times and the belt has slipped. I will just call the dealer and see what they say to do.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
