Will This Clutch Fit a 99 Scrambler 500 4X4?
Old Aug 3, 2003 | 01:42 AM
Jeepman1991's Avatar
Default Will This Clutch Fit a 99 Scrambler 500 4X4?
Ebay Add
It says "engine braking", mine doesnt have that, are they the same clutches?
Old Aug 3, 2003 | 01:56 AM
BigBadScrambler's Avatar
I think that you would have to get an EBS secondary clutch too. Any other non EBS clutch would work but if you have the EBS primary you need the EBS secondary. Someone correct me if Im wrong. What happened? Do you need a new Primary clutch?
Old Aug 3, 2003 | 02:03 AM
Yes, this will be number 3 for the Scrambler junkbox endless money pit.
Old Aug 3, 2003 | 02:10 AM
3 primary clutches??????? sounds like it may be more of a different problem than just the clutch. What exactly is happening. Oh, I found some more on ebay. These should fit here here here
Old Aug 3, 2003 | 02:11 AM
None of those fit a 500 homie, I have seen them all.
Old Aug 3, 2003 | 02:15 AM
As far as I knew there were just EBS and Non EBS clutches. I thought that they were all interchangable, just require different weights and springs. Maybe someone will stop by and clear this up
Old Aug 3, 2003 | 03:25 PM
95sport400's Avatar
I think BigBad is correct. Any non-EBS should be interchangeable. I would also agree with him that there is something else wrong if you're going through clutches like that.
Old Aug 4, 2003 | 10:27 AM
NCScrambler's Avatar
I agree with both of you also. <U>All</U> non-ebs clutches and components are interchangeable and all ebs clutches and components are interchangeable. Now one clutch from one machine may be set up differently than your madel, but a spring and weight change should be all it takes to make it work. Read the post titled "01 trailboss adjustment", I posted a link there for proper adjustment of the clutch. You clutch is definately adjusted incorrectly for you to be going through clutches like that.
fordfaithful21
Dec 7, 2015 05:52 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
1000gade
Sep 9, 2015 03:35 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
