No shifting !
Old Sep 22, 2003 | 11:56 AM
lovemud's Avatar
Default No shifting !
Which way was the engine twisting and what did you observe with the clutch?
Old Sep 23, 2003 | 01:13 AM
XPLORED's Avatar
The engine was twisting so that the distance between the clutches was decreasing, so what the clutches looked like was once you increased RPM the primary clutch would close and just when it looked like the secondary was going to open the engine would start to twist and the secondary would not move after this ! *&@#$%$#@&* Would worn springs,buttons etc... cause something like this ? This one is new to me !! Thanks for any thoughts!!!
Old Sep 23, 2003 | 05:48 AM
ktxl's Avatar
If the engine clutch bolt is only moving 3/16 to 1/4" do not worry,this is normal on stock motor mounts,the mounts are soft so engine can (shake)without vibrating the plastic .Did you ever look in the HPD or Hot Seat catalogs and see the performance motor mounts?They are made of stiffer rubber to keep engine aligned for better performance.There are a few companies even selling a torque arm you bolt to the motor and the frame to keep motor from twisting.(not recomended for trail riding though)Take that driven clutch apart and check those clutch buttons!!!
Old Sep 23, 2003 | 10:30 AM
lovemud's Avatar
Yea, sounds like the problem's in the secondary. Make sure you've got a GOOD snapring pliers.
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
