Help installing cv joint polaris 500 sportsman
Old Sep 29, 2003 | 09:46 PM
Farmr123's Avatar
Default Help installing cv joint polaris 500 sportsman
Tap GENTLY with a punch on one side, and that should rotate the other side out to where you can get a ball in, rotate it a little with the punch, and work your way around.
If it doesn't move freely, the outer part of the joint may have been galled when the CV went bad.
Farmr
Old Sep 29, 2003 | 11:05 PM
Traildog's Avatar
One additional tip, smear a little grease in the cage and carrier cos they don't rotate worth a darn when dry even with all the ***** in.
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
Mphillips
Jul 2, 2015 07:20 PM
