Counterbalance bad???
Old Nov 19, 2003 | 07:22 AM
NascarFan's Avatar
Default Counterbalance bad???
I had my engine out when I did mine, but I did a top end rebuild at the same time. The guys at the polaris shop leave the engine in.
Old Nov 19, 2003 | 08:35 AM
quadwrench's Avatar
If you have not done this before, I would suggest pulling the engine so you can have room to work and "see" what you are doing. It does't take much longer to go ahead and pull the engine.
Old Nov 19, 2003 | 10:25 AM
pudljumpr's Avatar
If you're gonna tear it down, redo it all while you have it out. crank berrings as well. Go ahead and replace waterpump seals, cause I've seen them go out after time, ruin the berrings, and shell the case. It may cost a little more, but save you a lot of swearing in the long run...you'll have a fresh engine thats ready to rumble!
cwbond007
Dec 20, 2020 05:48 AM
chsimpson217
Jun 21, 2009 07:18 PM
tripd
Jun 19, 2009 12:06 AM
patrickvol1
Nov 22, 2006 09:59 PM
TINKERMAN
Mar 8, 2004 03:35 AM
