Clutch Springs
Old Jan 6, 2004 | 10:44 PM
rocketdeerdog's Avatar
Default Clutch Springs
I was wondering what exactly happens when you change the clutch springs? Does it change the engagement RPM's?
Old Jan 6, 2004 | 10:49 PM
Traildog's Avatar
Yes.
Old Jan 6, 2004 | 11:37 PM
Does most people increase the engagement RPM or lower them?
Old Jan 6, 2004 | 11:49 PM
MnFriesen's Avatar
to answer your first question the Primary clutch spring changes rpm engagement...secondary changes belt tension
second question
Increase...
Old Jan 7, 2004 | 01:57 AM
Traildog's Avatar
Most people replace the stock primary spring with a stronger spring thereby increasing the rpm engagement.
Old Jan 7, 2004 | 09:56 AM
Bubba297's Avatar
Of course there is a lot more to it than just changing the spring. If you change the tension rate or full shift pressure then either the bike will turn too many RPMs and get out of the pipe operating range, or the clutch will never fully shift out. Performance can suffer with a spring change more easily than it can be helped. The best thing to do is call someone who deals with clutching and tell them what you have and what you want. That would be the best thing to do. Ritter Cycle would be a good choice.Bubba
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
