how much power and speed would i get from these mods.
ok i already know what i want for christmas (little while away but im set for now). ok heres the mods, RCR Porting maybe bubba porting, RCR Head Work, RCR Quick Rev Flywheel Modification, Cylinder Boring, Wiseco Piston, and a 38mm tmx flatside carb. currently for mods i have a hpd pipe, hpd clutch kit, and k&n air filter. i have about 32hp right now. what would my hp number be after these mods. how much mph will i gain. everything cost right around $760. is this a good deal? anything else you would reccomend along with these mods. money wont be a problem as i will be asking for christmas and b day (b day 2 days after christmas and im turning 16 so its a special b day) thanks for any input!
those things you call custom floor boards u should be cutting and griding the point closet to the front tire b/c if that thing rolls on your leg or somthin its going through. and it looks like u used good old small pop rivets to hold the peg on. it will hold up probably but u should thinkin about getting somthin a lil stronger bigger pop rivets, tinners rivets or somthin not bashing u man but i had a friend that had like a spike on his pegs on his motorcyle and he wrecked and it went half way through his leg
bt250racer its just a risk im gonna have to take and the small pop rivets are actually pretty strong too. nice man the handlebars saved me about 5-7 pounds, the floorboards are about 10, the plastics being cut is like 5, thingson the frame i cut off is the rest. it might actually be like 27 but its just a rough estimate.
ok thanks tbsleeper. i was planning on gettin rid off the oil injection. new handlebars really save you that much weight. where can i find a pair of good handlebars. mine are really bent right now i have another pair of the stock ones but hav not had the time to put then on. i am just used to the bent ones.also i dont think i would remove the electric starter because my hpd pipe rest right on my pull starter and is a pain to pull.
