horn
Old Mar 30, 2004 | 12:10 AM
BigBadScrambler's Avatar
Default horn
I did not use a fuse. It may not be a bad idea though.
Old Mar 30, 2004 | 02:41 PM
jtrundle's Avatar
Default horn
I read in another post that you should buy a relay. Is this true? Or can you just hook it straigt up to the override button? Give us the step by step...
Old Mar 30, 2004 | 06:39 PM
Default horn
All I did was splice into the purple wire that comes from the override button. The purple wire has power to it when the button is pushed in, that way the override button could be used for the horn. Then I just bolted the horn to the frame under the front cowl and conected the power wire (spliced into the purple wire) and the ground wire (connected to the mounting bracket) to the horn. It worked for me[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 31, 2004 | 01:42 AM
moosehunter's Avatar
Default horn
All I can tell you is BE CAREFUL!!! Horns draw a bunch of power and could easily melt your button. Use a relay or you could end up being the next Captain Zip-Kapow!! [img]i/expressions/face-icon-small-shocked.gif[/img]
MikeyBoyesq
Nov 27, 2020 02:44 PM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
scram5050
Sep 3, 2015 05:06 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
MaxAZ
25
Aug 30, 2000 10:40 PM
