Dayco Belts
Old Aug 3, 2000 | 10:42 PM
MudGuy's Avatar
What is everyone's experience with Dayco belts & what are the Dayco part numbers for EBS & non EBS belts?
Old Aug 5, 2000 | 12:06 AM
Rictor774's Avatar
Dayco Max belt for the Non-EBS is part # Max-1121.
The belt last much longer than stock and seems to have less slippage.
Hope this helps you out, later Rictor.
Old Aug 5, 2000 | 12:11 AM
MNXPLORER's Avatar
Its a little soon to tell, I've only got about 20 miles on a dayco max and I'm not real impressed. I just put in a EPI clutch kit and a Ram valve reed cage and spacer into my 400 xplorer. I can burn the dayco belt and not the polaris I just replaced! I think I'll stick with the stock belts from know on. Maybe it just needs to be broke in.
Old Aug 5, 2000 | 01:42 PM
Tim1's Avatar
Dayco is a good belt but there Ultimax is there top of the line right now . I'm not sure if there is a Ultimax made for EBS because I have only seen them on hight performance snowmachines.If you have non EBS then the will have the correct size for a quad.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
