Polaris Trailblazer info needed
Old Aug 9, 2004 | 12:55 AM
SandZilla's Avatar
Default Polaris Trailblazer info needed
I have a 95 Trail blazer and the tranny is shot I need a little info on removing it. The only thing left to remove before I can take it out is the output shaft that the fromt sprocket and brake disc mounts to. How do you remove this shaft so I can take out the tranny? Thank you. BTW this is the first american made quad I have owned. Thank you for any help.....
Old Aug 9, 2004 | 02:56 PM
SandZilla's Avatar
Some one has to have a manual
Old Aug 9, 2004 | 03:05 PM
tbsleeper's Avatar
not many of us on here have the older setup like u do...i think ummmm o crap forget the name has one
Old Aug 9, 2004 | 09:37 PM
SandZilla's Avatar
Thank you, thank helps a bunch.
Old Aug 9, 2004 | 09:42 PM
thewayout420's Avatar
does this help you any?
Old Aug 10, 2004 | 01:42 AM
Whuggs1's Avatar
I have a 96 TrailBoss that should be about the same, You have to remove the brake and rotor first. then a steel plate If i remember correctly.There will be a snap ring holding the sprocket on I think.
Old Aug 10, 2004 | 02:16 AM
scrambler123's Avatar
sandzilla no one is going to help you if you get an attitude when you're not helped right away. If you were being sarcastic nevermind but if you were use a [img]i/expressions/face-icon-small-smile.gif[/img] next time.
Old Aug 11, 2004 | 11:33 AM
SandZilla's Avatar
LOL [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 11, 2004 | 07:56 PM
ftwflh's Avatar
Have you dropped your swing arm?If I am not mistaken I had to take the swingarm all the way off of my 425 to get it out.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
AK47KID
Jul 23, 2015 09:21 PM
hoopduerr
Jun 2, 2015 09:01 AM
FourWheelOverTwo
May 31, 2015 07:26 PM
