Need Recommendation for 700 EFI body protection
A couple weekends back I banged up some of the front area under the front tow bar hook by a rock. Actually below and to the left of the two gold bolts at the bottom. It's not real bad but was thinking I should look into some kind of guard or skid plate to protect it in the future.
What do you all recommend for protection in the lower front end area under the radiator and out in front about a foot up?
Thanks!
Treacherous
Thanks!
Treacherous
If I remember correctly it does come up to the bottom of the raidators grill and a little higher hence the cut outs for air flow. However a good straping point to move to is the metal under the floorboards I strap all my quads there and have had not problem yet. Long trips I usually have a locking cable on the quad through the frame which is there for security but if it does come loose it is another strap.
Finally got around to ordering this. Is this a less than 30 minute install?
Nose Armor
Looks like a simple install.
Elkaholic
09-06-2015 02:44 PM
