counter balance replacement
Old Oct 14, 2004 | 10:22 PM
Swampyhunter's Avatar
Default counter balance replacement
My water pump was leaking into my crank case. When I pulled open the water pump I can see
that the water pump shaft is messed up. I did not pull the engine . Can anyone tell me tell me
if I can remove and replace the water pump shaft or is it all one piece or and I need to replace the whole counter balance.
thanks
Old Oct 14, 2004 | 10:27 PM
Jayblazer's Avatar
its been a while since anyone brought up the old counter balance i guess your talking about a 400cc 2-stroke? if so your Probably going to want to do it right that means new bearings pressed onto the counterbalance and new seals on the water pump what kind of shape was your impeller in? your best bet is to get ahold of Rick Ritter he really helped me out when mine was blown also if you need new parts check e-bay...
Old Oct 14, 2004 | 10:41 PM
Yes it is the 400cc 2- stroke. I got the bike some one who had it laying up for some time. When I was removing
the nut for the impeller the water pump shaft unscrewed from the counter balance . Is the pump shaft normaly
threaded into the counter balance or was it some type of rigging job.
Old Oct 14, 2004 | 10:44 PM
Jayblazer's Avatar
here this may help you out and yes thats the way they are counter balance
Old Oct 14, 2004 | 10:53 PM
Thanks for info. I looked at several part break downs but I could not find a part number for just the water pump shaft. I even called a few polaris dealers and they was not able to help me.
Old Oct 14, 2004 | 11:19 PM
Whitedog's Avatar
Hmmm... Mine was all one piece, what year is it?
Old Oct 14, 2004 | 11:23 PM
Sorry I must have left the year out it is a 1995.
Old Oct 14, 2004 | 11:51 PM
Jayblazer's Avatar
like i said call rick he rebuilds them the counter balance itself is about $375.00 new he can get you hooked up much cheaper...
Old Oct 15, 2004 | 12:00 AM
I will call him tomorrow. Thanks for all the help.
toonces
Aug 5, 2015 05:55 PM
U2OFlyer
Aug 5, 2015 12:46 PM
toonces
Jul 28, 2015 01:58 PM
trouttracker
Jul 20, 2015 11:54 AM
jettman
Jul 6, 2015 12:16 PM
