500HO stalling...please help!!!
Old Dec 12, 2004 | 09:57 PM
snowmann's Avatar
Default 500HO stalling...please help!!!
Hello all,
went out and plowed for the first time and the machine kept stalling. It will start right up again though and let me go another 200 feet or so but then stalls again without warning just quits....also, backfired once...pleae help i needd help,,,seems to idle slow also
thanks for any info and merry christmas
Old Dec 12, 2004 | 10:28 PM
hondabuster's Avatar
Slow idle will cause that, and so could a dirty carb.
Also old gas,and low float level could cause that.
Where was the throttle position at when it dies? Idle, 1/2 open ?
If turning up the idle doesnt fix it, drop the float bowl and check for crud.
Old Dec 12, 2004 | 10:58 PM
snowmann's Avatar
hello,
it stalls at idle and around half throttle
Old Dec 12, 2004 | 11:02 PM
1Bullmoose's Avatar
Snowmann,
Sounds like a problem I had last year. Before you tear things apart, you might want to check the throttle cable freeplay adjustment at the handlebar. The Electronic Throttle Control (ETC) will cut the engine if the adjustment isn't correct. The throttle cable stretches after a while and the slack needs to be taken up.
Old Dec 13, 2004 | 01:35 PM
snowmann's Avatar
thanks hondabuster and 1bullmoose...i will try all u two mentioned ,,,thanks
Happy Holidays!!!
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
pro94lt
Aug 20, 2015 10:02 AM
WilliamBos
Jun 13, 2015 08:51 PM
yoopermike
Nov 6, 2002 11:45 PM
bubbagodkin
Apr 18, 2001 03:33 AM
