2ndary clutch question..
Old Jan 11, 2005 | 02:36 PM
lepper's Avatar
Default 2ndary clutch question..
How high, when the wheeler isn't moving.. should the belt be sitting on the 2ndary clutch? my belt doesn't go altheway into the 2ndary. there is about an 1/8th of an inch sticking above the clutch. Which would explain how my last belt wore out.
The teeth of the belt were worn off and gone but the flat?? part of the belt was intact...
so.. anyone have a picture of how the belt should be sitting on the 2ndary??
thanks.
d
Old Jan 11, 2005 | 02:41 PM
POLARISFREAK's Avatar
1/8 of an inch sounds about right! That's what I run mine at. When is' even with the secondary, it's time for a new belt!
Old Jan 11, 2005 | 06:48 PM
xcrider's Avatar
yep, 1/8 sounds right. This is "low gear" and will quickly shift into the secondary once you start moving
Old Jan 11, 2005 | 09:22 PM
lepper's Avatar
how quickly should it shift in? It's on a 99 500 scrammy and when I took it for a spin and watching the clutch with the cover off it didn't quickly get into the primary.... I had to actually go a good clip to get it to get into it..
d
Old Jan 12, 2005 | 12:39 AM
homdaddy's Avatar
living in bandon i take it you ride the coos area a lot and i would bet that you have a nice goove wore in the primary clutch. down in the dunes riding around the old 500 doesnt shift up to fast and they tend to bog down a little causing the belt to get hot . plus they ride right up the sheeve a little and start to wear a groove. when i worked at the ol pol dealer ship we would re place lots of drive clutchs do to this.
Old Jan 12, 2005 | 01:01 AM
lepper's Avatar
actually I think i've only road the dunes about 4 times.. I stay away in the summer and do a lot of woods riding on closed roads.. [img]i/expressions/face-icon-small-smile.gif[/img] but there isn't any grooves worn.. i bought this from eastern wa..
d
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
