Guys, check your throttle cables again. Yes Even the 2005's
Old 02-12-2005, 11:18 PM
jefffoxsr's Avatar
Default Guys, check your throttle cables again. Yes Even the 2005's
The problem with the 2004's was well documented, and so was the fix.
There are 3 areas on my 2005 that rub the frame. I thought I took care of it, but my solution didn't work. I put padding on the frame. The rubbing of the throttle cable still wore away the covering. I only have 85 miles.
I wrapped electrical tape around the 3 areas. Hopefully that will be adequate.
Old 02-12-2005, 11:51 PM
elkbow's Avatar
thanks for the info Jeff....I've been watching mine, but i'll check them again....
dave
Old 02-12-2005, 11:55 PM
jefffoxsr's Avatar
I was in there tonight and noticed a black powder on the white padding I stuck to the frame. Upon futher inspection I noticed that it was the covering from the throttle cable.
Also check all your hose clamps. All of mine were quite loose when I got the quad. I spent a few days going over every nut and bolt.
Check your alignment too. The Polaris spec is toe out and mine was toed in 5/8". I checked several times to make sure.
Old 02-13-2005, 01:51 AM
elkbow's Avatar
One of the first things I did with my machine was check all the bolts. In my thread on drive fluids I recommended that everyone check their drain bolts, as mine was only slightly more than finger tight. Granted, they don't have much torque needed on them, but these were almost loose.
Some of the other things to check are you battery cable bolts, wheel lug nuts, rack mounts, etc.
All bolts should be checked on a regular basis. I worked on a Honda Foreman a couple of weeks ago, one of the symptoms was that when cranking it over it would die and all lights would go out. The battery bolts were finger tight....
Old 02-13-2005, 02:28 AM
jwyles's Avatar
Thank you for the info. I will need to check all that on both of mine...
Old 02-13-2005, 05:19 AM
Lukester's Avatar
I checked and recheck mine regular (all bolts I can get too). I found one of the two clamps that hold the hande bars on to be loose. you of course have to remove the plastic cover to get at mine anyway. Glad I looked there.
Old 02-13-2005, 11:32 AM
20045SP500HO's Avatar
I found tape wouldn't last ... try using rubber fuel hose, i found that lasts ALONG time.
Old 02-13-2005, 01:04 PM
jefffoxsr's Avatar
Thanks Chris
Old 02-13-2005, 07:53 PM
[img]i/expressions/face-icon-small-smile.gif[/img]
02Chevrolet
1) Engine problems..
06-23-2015 12:12 AM
Quadknewbie
06-05-2015 09:58 PM
kevbowe
06-01-2015 01:17 AM
OLDSTER
01-09-2001 10:13 PM
Quick Reply: Guys, check your throttle cables again. Yes Even the 2005's
