pred cdi box and rectifier
Old Mar 27, 2005 | 09:35 PM
cr125predator's Avatar
Default pred cdi box and rectifier
i am looking into a cdi box and rectifier. all i know is that you will get some more rpms. do you have to have a special one for the 2005's and what are some good ones and where can you get them. thanks
Old Mar 27, 2005 | 10:57 PM
RAJ's Avatar
RAJ
I would not worry about the rectifier. The cdi box for the 05 has a different plug in, then the 03 & 04. I have been waiting for Doug to get his out. I called Dyna and they said they are on back order and they should be out in a couple of weeks. I know Dougs makes a big difference! You do not want to buy one of e-bay. Doug's, Dyna, & Vortex will raise the rev limiter and change the power curve.
Old Mar 28, 2005 | 12:47 AM
will the power curve change the how the TLD preddy boggs when you hit 5th. and how many more rpms do you think i will get. oh and you said you put a turn down tip on your slip on, where did you get that
Old Mar 28, 2005 | 12:58 AM
RAJ's Avatar
RAJ
The power curve will be through out the entire power band. So 1-5 gear it will scream. I got the turn down tip from Doug, he only has a few, and they will not be any more made. You will have 10,600 rev limiter. You should not be able to hit it. I have 2 buddy's the the cdi box, and they have never hit it yet.
Old Mar 28, 2005 | 01:02 AM
ok thanks a lot, if you get one tell me about it
Old Mar 28, 2005 | 01:28 AM
RAJ's Avatar
RAJ
If Doug ever gets them out.......I will have one for sure. I would love to get his, the cost is $150.00, and the Dyna is like $325.00. But I will have one or the other in a few months for sure.
Old Mar 28, 2005 | 01:36 AM
pooboy2's Avatar
not to steel your thread but what do you think abought a lightend flywheel on an 04 predator there raj?
Old Mar 28, 2005 | 01:43 AM
RAJ's Avatar
RAJ
I really don't know what to think! I would much rather have a port and polish job done. They are other ways to get better trottle response and have it rev alittle bit faster then shaving the flywheel. I would never do it, but thats just me.
Old Mar 29, 2005 | 12:51 AM
raj, will the cdi box burn up your motor faster?
Old Mar 29, 2005 | 01:07 AM
RAJ's Avatar
RAJ
I would think making it run more RPM's would put so ware on the engine. But as long as you don't hit them RPM's alot, I think you will be fine. My buddy's have Doug CDI box and I don't think they are putting any extra ware on the engine.....just because how they ride. They don't try to hit the 10,500 rev limiter every time they shift. Just be careful if you get one, another thing if you are hitting you limiter now alot you are doing more damage to it, then running higher RPM's.
Joe454
Nov 20, 2020 01:19 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
BYC
Sep 25, 2015 02:10 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
johnny1982
Sep 13, 2015 07:41 PM
