95 Explorer 400 info???????
i recently blew up my 95 explorer 400...bore job piston crankcase rod and pin later its almost back together......i am however having a hang up with a ground wire...i just cant remember where the ground wire from the battery runs too...i knwo that i couild easily just bolt it anywhere to the frame but i want it to be in the original spot.....i was going to take the time to mark all wires when i dissasembled it but i thought i would put it back together right away...the only problem was that it took polaris a month and a half to produce more cases and i had to wait to put it back together...
greg86hd
09-16-2015 12:32 AM
