"Green Spring"
Old Oct 13, 2000 | 12:36 AM
  #41
Xplor's Avatar
Skid,
To be totally honest I do not remember exactly how my Xplorer rode before the clutch kit. All I do know is that I wanted more "ooumph" at the time. I had it installed two years ago. I remember getting on it and feeling much, much better acceleration and backshifting. I do not think it engages much higher than stock because I can crawl like I used to over/through anything. It just "feels" much stronger. It seems to engage relatively the same but after that it just powers up a heck of a lot more.
I thought that I would loose some top speed but the dealer tested it last year and was amazed to hit 65mph.
I am not sure of the spring color as I am not the one that did the work back then. I didn't even know how to clean the air filter back then...
I wish I knew someone with a stock Xplorer to test it with...
Brian
Old Oct 13, 2000 | 04:16 AM
  #42
Bill.Ciliberti's Avatar
According to my Polaris manual,there is very LITTLE differance [you would not feel it] between the white and green spring.Compressed spring length on white is 1.19,the green spring is very close to the same.Full upshift on the white spring is around 140lbs,the green spring is around 142lbs.These springs are so simaler,that im not even certain why they make BOTH of them.==Bill
Old Oct 13, 2000 | 11:12 AM
  #43
leel's Avatar
How different is the WHITE spring from the stock spring? Or is the WHITE spring the stock spring?
Thanks,
Lorrin
Old Oct 13, 2000 | 01:14 PM
  #44
Blue/Green is stock.Look at my earlier post,it explains very little differance in the white/green springs,
Bill
Old Oct 13, 2000 | 02:42 PM
  #45
toyman's Avatar
Thanks Bill, I also have a new belt -i rode around today and the engagment RPM is a little lower now that the belt streched a bit. I like the spring now.... Can't wait to jump in a mud hole!!!
700quadman
Aug 19, 2005 12:12 AM
KISSSOFDEATH
Apr 10, 2004 06:04 PM
rideitlikeustoleit
Oct 22, 2002 10:59 PM
Farmr123
Oct 18, 2000 01:07 PM
