secondary roller clutch question
Old Jun 28, 2005 | 10:24 AM
Speedwerx's Avatar
Default secondary roller clutch question
The set-up you have now is for sea level, but I'm not sure if team has a different set-up for higher elevation for that machine I would assume they do but we have never had to set one up for that elevation adn team is closed rightn now until the 8th of july. we shoud lhave no problem getting this figured out though. Do you have any other mods done to your machine like pipe. primaruy cluthc mods, filter, cam, anything let me know and we can go form there. Do you have a tach on your machine?
Old Jun 28, 2005 | 01:33 PM
ToSlow's Avatar
I'm running 10RH wieghts with a white spring on the primary a K&N filter with a IDS2 Supertrapp exhaust thanks for checking this out for me
Old Jun 28, 2005 | 04:02 PM
Speedwerx's Avatar
What rpm are you turning and what rpm do they suggest with that pipe? Do you have a tach?
Old Jun 30, 2005 | 05:31 PM
ToSlow's Avatar
Not sure what rpm I'm running and not sure of what tach will work on it there wasn't any recomondation in the instructions for the rpms I've got it tunned for more bottom to mid range
Old Jun 30, 2005 | 06:14 PM
  #15
Speedwerx's Avatar
They don't tell you what rpm the pipe is supposed to run? That is not a good thing, try and give them a call to find out or maybe someone ready has one a knows. I know with our 500 scam. ex. we run 6500-6800. Stk. is like close to 6200 I think.
Old Jun 30, 2005 | 07:54 PM
  #16
ToSlow's Avatar
but with the silencers with the discs wont the rpm vary with adding or removing the discs
Old Jul 5, 2005 | 10:59 AM
  #17
Speedwerx's Avatar
I'm not sure I have never ran there ex. on that machine. I do believe that is how they work though but if they say there ex. adds xx hp they shgould know what rpm its at?
ghost civic
Jan 15, 2020 07:43 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
