low end clutch kit-scrambler
Old Jul 10, 2005 | 08:33 PM
ftwflh's Avatar
Default low end clutch kit-scrambler
Originally posted by: garrett5462
would that add low end and keep the same top speed?
Put a White Bros slipon muffler and it will get you more bottom end.
Old Jul 10, 2005 | 09:25 PM
garrett5462's Avatar
Originally posted by: ftwflh
With the stock motor (no pipe) I would go with a Polaris green or Dalton Black/white primary spring and either an Aaen Blue or HPD violet secondary and you will be happy.Totol expense less the $60
alright, so if i did a search like one ebay and searched for a polaris green primary spring and i found one, will that spring fit my quad? do they come in different sizes or are the colors the different sizes or tensions? also, if i put in the new springs, should i put on a new belt while im at it also.
Old Jul 11, 2005 | 02:05 PM
bumper
Old Jul 11, 2005 | 02:13 PM
scramblerXrated's Avatar
the polaris primary springs are all interchangeable. the colors represent the spring pressures.
X
Old Jul 11, 2005 | 03:25 PM
  #15
alright, then i think ill find a polaris green primary and an aeen blue secondary.
Old Jul 11, 2005 | 05:39 PM
  #16
jimk72's Avatar
If you decide to get a new belt look into a Dayco HP belt or a gates. You can get them alot cheaper than the polaris replacement and are a much better belt I feel.
Old Jul 12, 2005 | 10:14 AM
  #17
will that belt last longer than a regular polaris oem belt?
Old Jul 12, 2005 | 04:21 PM
  #18
chevyboy400's Avatar
garrett, i sent you that message. the green primary might be a little loose for your needs. i like the brown primary. you can pop good wheelies and still keep the front tires on the ground whenever you feel like it. I would highly reccomend for holeshots too. you shouldnt have to change the clutch, even thought that might help a little bit more, the components are a lot cheaper than a clutch kit.
Old Jul 12, 2005 | 06:01 PM
  #19
ftwflh's Avatar
Dont think about the brown spring with a stock motor and no new clutch weights you will loose your lowend power and over rev your motor.Now if you go with a complete HPD kit the brown is run with a set of 10-56 weights and a violet secondary to get the rpms down on engagement and topend.That is thier '"agressive" kit.
Old Jul 12, 2005 | 06:23 PM
  #20
so your saying that i shouldnt buy just a new primary, i should get a whole kit? or ae you just saying to not get the brown spring? i was shooting for just a green primary to put on it to get a little more low end.
