low end clutch kit-scrambler
#31
Well, the kit costed $620. Its a fogger kit, so it can do damage to your engine if you are on the button too long. 3-5 second shots at a time, i have the oil tank wtih extra gas with a gas pump for the nitrous. I have much more top end than low end, but the stock pipe is just not cutting anything. The nitrous is pretty cool, but i wanted better results from it. at about 50mph, you spin the tires pretty good on the button, but no flames from the muffler. you cant go with too big of a bottle, you will have trouble finding a place to put it. mines where the tool kit used to be. if you are going to get nitrous, get a oil blockoff kit so you can have the oil tank for the extra gas needed.
#33
Originally posted by: garrett5462
so about how much is just a primary spring, and if color matters, green.
