low end clutch kit-scrambler
Old Jul 8, 2005 | 11:58 AM
garrett5462's Avatar
Default low end clutch kit-scrambler
what is a good low end clutch kit for a scrambler that isnt that expensive? im looking for one that will just blow by other quads of the line, but still have the same top speed.
Old Jul 8, 2005 | 02:19 PM
scramblerXrated's Avatar
check my sig.
mine has great low end, off the line launches!
X
Old Jul 8, 2005 | 04:05 PM
do u still have the same top speed? can you do good wheelies...[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 8, 2005 | 04:06 PM
wait... was that a kit you bought or did u just buy the primary springs? wouldnt be cheaper if u just buy the springs?
Old Jul 8, 2005 | 04:33 PM
its a combination that i put together after trying several different setups.
but it would be cheaper to buy the components separately i think. (not including the TEAM setup of course)
X
Old Jul 8, 2005 | 05:00 PM
did u order the springs and weights all from the same place? how much did it cost you?
Old Jul 8, 2005 | 05:57 PM
jimk72's Avatar
If you buy a kit it will come with a new helix and everything else but then if you decide to get a team secondary you now have a useless helix. If you just want a better holeshot try a new primary spring($20). Ask if anyone that got a team secondary still has there helix from the clutch kit they had and try to get that. Then save up for a team roller secondary and you will be all set.
I paid $164 for my clutch kit and now am thinking of buying a team secondary later this year. So I wasted the extra $90+ on a helix I will not need once I get the team secondary.
Old Jul 8, 2005 | 06:56 PM
ya what jimk said,
i ended up buying a few used clutch kits offa ebay, and they had different weights and springs that i played with.
you can find used springs pretty cheap on ebay if you keep a sharp eye on it.
X
Old Jul 8, 2005 | 07:11 PM
ftwflh's Avatar
With the stock motor (no pipe) I would go with a Polaris green or Dalton Black/white primary spring and either an Aaen Blue or HPD violet secondary and you will be happy.Totol expense less the $60
Old Jul 10, 2005 | 06:11 PM
would that add low end and keep the same top speed?
