low end clutch kit-scrambler
#53
you can try running a spring shim if you want a bit more spring pressure. you can get them from bike bandit or your dealer.
Its basically a large washer that goes between the clutch and the spring.
#54
Originally posted by: scrm4x4
i put the green spring in today and love it my dealer had it in stock 24.00 and i put a new belt on a gates with kevlar it took 15 minutes no problem thanks guys......
#57
to make things easier: put the spring in and leave it at that. ride it around a bit, if you dont like it you can tinker with it if you want. just use a little trial and error, it will be a lot faster.
#59
i put in the white primary. i like it. i can do better wheelies and it seems like a little more acceleration. i just dont like how i dont move until i rev that sucker way up.
