C-Series wheels on a 700 Sportsman
Old Jul 8, 2005 | 07:22 PM
SnowDrift's Avatar
Default C-Series wheels on a 700 Sportsman
I'd like to take off the chrome factory wheels from my '02 700 Sportsman and put on a set of aluminum ITP C-series wheels. I'm keeping the factory Goodyear Rawhide Grip tires. I notice that the wheels I like are offered in 12 x 7 only, for the fronts and the rears. Is anyone else running these that can provide a photo? The factory wheels are wider in the rear than the front, so I want to make sure these will fit before I make a purchase.
Also, is the offset greater on these wheels than the factory set? I don't really want to be any wider than I already am with this.
Thanks,
SnowDrift
Old Jul 8, 2005 | 08:58 PM
SPORTSMAN70003's Avatar
I have some on my 700 click here for pics. You can also click on my camera and I think they are a pic of them in there also. The 12x7 will work front and rear. They will make you wider with these wheels.
Old Jul 9, 2005 | 11:48 PM
SnowDrift's Avatar
Thanks! I thought I looked at yours yesterday before I posted, but it must have been someone else's. How much wider did you end up? Hard to see what is happening with those straight on views. Any chance of a good corner shot?
Nice gauge setup! Are those VDO to match the OEM pod? And, also, nice pipe addition with the dual pipes. Any mods to get that to fit? I'd love to have a water temp gauge and oil press. guage like you have. Where did you tap in the engine? If you used the factory holes, did the speedo. pod give you any errors or trouble?
Thanks again,
SnowDrift
Old Jul 10, 2005 | 12:14 AM
I didn't measure but I would guess it would be close to 2" wider. I'm going to try and get some more pics up soon of the wheels and tires.
The gauges are Equus brand from O'reilly auto parts. I bought the triple 1 1/2" gauges and didn't use the volt meter. The bezels come silver and I painted mine black. They are pretty simple to hook up. You have a temp sending unit on the left side and I took it out and used the sending unit with the gauge. Below the temp sending unit they are a plug that takes an allen wrench to take it out thats where you hook up your oil pressure line. The speedo has never give me any errors.
The 800 header I had to cut a little piece of the floorboard off but if I didn't show you it would be hard for you to see. I also bent the shifter rod just a little so it wouldn't hit the header. I also slotted the mounting holes on the muffler so it would slide forward and seal to the header.
If you have anymore ?'s let me know.
Old Jul 11, 2005 | 08:21 AM
GITRDONE's Avatar
Thanks,
SnowDrift
See my pics in my gallery--
Old Jul 11, 2005 | 10:11 AM
SnowDrift's Avatar
Thanks to both of you! That was what I was looking for.
SnowDrift
Old Jul 12, 2005 | 05:27 AM
mtpockets's Avatar
Thanks,
SnowDrift
Snowie, i like these type-7 wheels...
http://cgi.ebay.com/ebaymotors/ws/eB...560691893&rd=1
~MT
Old Jul 12, 2005 | 05:39 AM
oondaddy's Avatar
Most ITP wheels have an extra inch of negative offset. That means they stick out 1 inch further than the stock wheels so it should be about 2 inches total
Old Jul 12, 2005 | 08:38 AM
SnowDrift's Avatar
mtpockets,
Those are sharp! The only drawback would be cleaning all those slots in the "bead lock" area. Real nice looking rims, though!
SnowDrift
Jmuddin284
Jan 19, 2026 07:16 AM
Big bousse
Sep 26, 2015 10:42 AM
Schneider
Jul 24, 2015 05:05 PM
Jul 21, 2015 03:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
