scrambler chain adjustment ( dont reply to other one)
i tried using the instructions in the universal owners manual, but, i looked, and it doesnt look like there is any way the rear end slides back to tighten the chain. does it adjust a lot or should i just buy a new chain or take a link out of the old one for now. any help is appreciated.
loosen the bolts holding the caliper
loosen the 2 bolts clamping the axle
use some channel locks to turn the axle at the large hexagon
it is a cam style adjuster
as you rotate the axle the chain will tighten or loosen
oh,,,then tighten the bolts back up
Click this link chain adjustment 101. If you still don't understand try #7 a few more times![img]i/expressions/face-icon-small-smile.gif[/img]
well, i knew how you loosen the two bolts holding the axel and the two caliper bolts, but i didnt get the part that it tells you to take a punch and put it through the sproket and into the housing and rolling the quad to tighten. you dont need to use a punch do you? is there an easier way? thanks for the fast reply.
alright guys thanks. also, once the chain is finished and streched out too much, whats a good chain? i was gonna look at rocky mountain atv mc and find a real strong x ring chain. theres one with an 8500 tensile strngth. whats a good chian you guys use cuz my chain is streching a lot.
Originally posted by: fishslab
Click this link <a class=ftalternatingbarlinklarge href="http://forums.atvconnection.com/messageview.cfm?catid=11&threadid=428622&highlight _key=y&keyword1=tightening" target=blank>chain adjustment 101</A>. If you still don't understand try #7 a few more times![img]i/expressions/face-icon-small-smile.gif[/img]
I just put a regina 520 oring chain & a new front sprocket on my 02 srammy and have not had to ajust
it since i put it on, no strech so far after 12 hours ride time.
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
