To Grease or not to Grease.....
Old Sep 4, 2005 | 01:35 AM
okiedude's Avatar
Default To Grease or not to Grease.....
Just dont insert that needle INTO the rubber boot. I did that thinking that 1 little tiny hole cant do harm and they both ended up tearing and allowing dirt and water to ruin the ends [img]i/expressions/face-icon-small-blush.gif[/img]....silly me
Old Sep 4, 2005 | 02:28 AM
Polaris500HO4x4's Avatar
haha they are sealed for a reason
Old Sep 4, 2005 | 06:04 PM
NBsportsman's Avatar
Just slip the needle under the lip of the rubber boot and work it in that way it won't tear it...
Old Sep 5, 2005 | 06:48 PM
THECVMAN's Avatar
Or you could just buy some extra clamps and remove them when you want to regrease. There only a couple a bucks.
Old Sep 5, 2005 | 07:05 PM
  #15
okiedude's Avatar
haha.....thanks
Old Sep 6, 2005 | 06:33 AM
  #16
floodrunner's Avatar
I’ve been greasing tie rod ends this way for years (ever since Polaris changed to a hiem style joint) on two machines, for a while three, and I’ve never had a single boot failure do to the little pin-hole of the grease needle. I’ve had outer boots rip do to trail debris getting spun between the inside of the tire and the boot but that had nothing to do with the needle.
Polaris does show the boot as a separate part that can be replaced independent of the tie rod end but I’ve had good luck repairing damaged boots with Plasti-Dip without any disassembly.
Old Sep 6, 2005 | 12:09 PM
  #17
Fixitmatt's Avatar
I drilled and tapped out holes for greese zerks eveywhere i could. i even put zerks on the ball joints of my predator and figured out how to do the swingarm.
bigred20653
Sep 19, 2015 02:11 PM
bmark0610
Sep 7, 2015 09:42 PM
rawbdiggity
Sep 7, 2015 12:05 PM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
