trouble getting power to the ground with 400 trail mod.
Old 09-20-2005, 03:54 AM
fishslab's Avatar
Default trouble getting power to the ground with 400 trail mod.
What kind of pressure are you running in your tires? Does it do it in low range too?
Old 09-20-2005, 10:31 AM
rieds's Avatar
i run 5psi in the front and back. i'm thinkin maybe i'm just throttle happy. if i ease into the throttle this isn't a problem. i'm gettin new wheels so i'm gonna have to go with 12 wheels on the back so i'm thinkin i'll leave the 589's on the front and maybe go with mud lites on the back. anybody else have any opinions on the effect of changing sprocket size on the awd?
Old 09-20-2005, 12:06 PM
duneaholic's Avatar
The heavier wheels may slow the wheelspin down some. I can't really relate to your problem to much cause in the dunes all that wheelspin comes in handy. Lots of traction.
Old 09-20-2005, 12:19 PM
fishslab's Avatar
I would make sure your gauge is accurate and drop the pressure to 3.5 to 4 psi. You'd be amazed at the extra traction that can be gained. Plus if it works, it's a pretty cheap fix.
  #15
conig's Avatar
reids the schanging of sprocket ration thing has been much debated, some have done it on a 4x4 no problem others caution against it, do a search and some home work and use your judgement.
Personally with what I have read I see no reason not to do it, but thats me and my opinion.
  #16
Old 09-20-2005, 12:21 PM
modquad's Avatar
If I remember right the Spider track style tires with a greater width. Match that up with a Hot Seat extended swingarm, and yes the gearing. You'll be rippin' and grinnin'. [img]i/expressions/face-icon-small-smile.gif[/img] Or was that grinnin' and rippin'.....no, the grin definitely comes after the rippin'. There's one perfect mathamatical equation in life. HP=happiness. [img]i/expressions/face-icon-small-smile.gif[/img]
  #17
Old 09-20-2005, 02:33 PM
scramblered's Avatar
getting the power to the ground is not a tires problems,but a clutch/gearing setup change is indeed the thing to check first.
  #18
Old 09-20-2005, 07:20 PM
DemonDS's Avatar
The way I uderstand the gearing on these is like this. I cant recall exactly how the chains run on these but I will try my best to explain. The ratio on the gears is figured to be the same rotational speeds of the tires front and rear. Thus if you change only the rear gearing, your rear tires will be spinning at a different rate than the front. this causes them to fight eachother and can cause some serious damage to your components. Ever change a tire on a truck and the spare not the same size and try to drive it in 4x4??? Doesnt go far. This only applies though if the 4 tires have traction. If all four tires are able to spin then it doesnt matter. Like those that run in the mud, makes no difference what the tires speeds are as they arent fully gripping anyways. The bad thing can also be though that it could change the way it will handle. 2x4's have no worries with this, makes notta bit of difference as the front tires have no drive obviously.
To learn better the effects of gearing and tire size, check out this gearing calculator, it is not Polaris specific with the PVT's but it will show you ALOT. Try different #'s of gears and tire diameters and you'll catch on really quickly.
links to gearing calculator
Youll have to click on the links on this page i provided. Thanks to the stupid filter on this site I cant link it directly.
  #19
Old 09-20-2005, 09:06 PM
fishslab's Avatar
If his tires are spinning, he is not having trouble getting the power to the ground. Maybe getting too much power to the ground. But spinning tires when he just has a trail mod, and he's only spinning in wet grass going up hill, is a traction problem. Could some clutching help? Yes. Could gearing help? Yes. Being clutched and geared correctly helps every vehicle.
Cole Hadden
08-24-2020 11:11 PM
Nondem
02-22-2020 12:20 PM
1000gade
07-16-2015 10:48 AM
sublime250
1) Engine problems..
07-11-2015 11:52 AM
tweeder
07-05-2015 01:57 PM
Quick Reply: trouble getting power to the ground with 400 trail mod.
