squish clearance
Old Sep 25, 2005 | 11:01 PM
modmaster's Avatar
Default squish clearance
HI i just removed material from my head do you need to cut the same amount into the squish area that you remove from the head thanks when i hit the gas at half throttle it pings and knocks real bad
Old Sep 25, 2005 | 11:24 PM
rieds's Avatar
how much did you take off? are you running high enough octane fuel for what you removed?
Old Sep 26, 2005 | 11:54 AM
Speedwerx's Avatar
Why did you cut the head to clean it up or to get better hp?
Old Sep 26, 2005 | 04:44 PM
conig's Avatar
I cut mine 20 thousands and didn;t thouch squish.I have no pinging issues on 93. How much did you cut it?
Old Sep 26, 2005 | 11:26 PM
modmaster's Avatar
I took it all the way down to were it was flat and reshaped the chamber and have some porting done
Old Sep 27, 2005 | 09:58 AM
Bubba297's Avatar
Wow! if it's a 250 you need another head to start with. If it's a 400 then the chamber will have to be opened back up and the squish clearance set at around .055. A lot of times on a stock head you cannot flat mill the head until the squish is right without throwing the compression ratio through the roof.
Old Sep 28, 2005 | 08:07 PM
modmaster's Avatar
ok it's a 250 and i did open up the chamber so how much squish do i need
Old Sep 30, 2005 | 01:36 AM
DuneMe's Avatar
What are you guys doing about your timing after making these modifications?
Old Sep 30, 2005 | 10:43 AM
Bubba297's Avatar
If the compression is kept within the limits of pump gas then timing doesnt need to be changed. A 250 should have around .045 minimum, but can go up to .060 without ill effects. The before mentioned .055 would be safest minimum for the 400. GOOD LUCK!
Old Sep 30, 2005 | 06:48 PM
modmaster's Avatar
what are the ill effects that could happen and for high compresion should the timing be retarded or advanced
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
