Winch contactor
Old Nov 13, 2005 | 08:30 PM
  #21
Instigater's Avatar
Default Winch contactor
Hey, one other thing, I took my buddies cable off his 2500 lb. I was looking for a lead type piece on the loop at the drum. There was not one there. Does it need one? My 2000 lb winch had one, but I did not know if these newer ones were different. Thanks
Old Nov 13, 2005 | 08:39 PM
  #22
tyler711's Avatar
I'm not sure about warn winches, but on my Superwinch, you stick the cable through a hole in the drum and tighten a setscrew on it - so the end of the cable is just a cut cable, with no crimp or anything on it. I'm not sure if you are asking about the cable or the winch?
Old Nov 13, 2005 | 09:13 PM
  #23
Charlie's Avatar
Anyone ever take these bad contacters apart and see whats wrong. I took one apart the other day and mainly it looks like the contacts themselves were burnt. That looked like they could be cleaned up but there is some small coil wires that break when you separate the two halves that would need to be repaired and would not be worth it time wise to repair. Polaris wants $100. and Warn wants $88.
The new contact assembly does look different and I wonder if it will last longer. Charlie
Old Nov 13, 2005 | 09:25 PM
  #24
tyler711's Avatar
My contactor stopped working on my superwinch a few months after I installed it. Superwinch sent me a new one, but asked for mine to see what had gone wrong. I told them I thought there was water inside (it only didn't work when it was under 32* outside), but they said they are very watertight.
THey called a few days later and said that it was indeed wet inside, apparently when the shop installed the winch, they took the mounting bracket off the solenoid and just bolted it in place. Superwinch said the mounting bracket was part of the contactor and kept it sealed; when I looked in the manual, it said this.
But mine didn't die on its own, it got wet after being submerged all the time after the shop broke its seal.
Old Nov 14, 2005 | 01:22 AM
  #25
Instigater's Avatar
I am asking about how the cable attaches to the winch. On Warn, I have only seen one, you shove the cable through a hole, then bend it around a (removable)metal piece and start to shove the cable back through the same hole. So basical the cable makes a 180 degree turn, and the metal piece wedges itself between the two cables. This sounds alot harder then what it is. LOL!!!
Old Apr 20, 2008 | 11:38 PM
  #26
DARETORIDE's Avatar
I have a extra winch and would like to connect it to a mount that will let me put it on the back of either of my 2 quads. I want to use the standard swithc to control either winch. The electrical also has to be a quick disconnect so I can switch between both quads. Any ideas? Where would I get info ont he MV7 setup and parts? Thanks...
Johnny Mac
Aug 15, 2019 03:13 PM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
toonces
Sep 5, 2015 01:14 PM
