PRELOADING THE HELIX
Old Jan 10, 2006 | 11:43 AM
naterj's Avatar
Default PRELOADING THE HELIX
WHEN YOU PRELOAD THE HELIX ON THE SECONDARY CLUTCH, YOU TURN IT 1/3 TURN COUNTER RIGHT. YOU HAVE TO LINE UP THE SPLINES ON THE SHAFT AND HELIX, SO DO YOU TURN THE PULLY COUNTER CLOCKWISE BEFORE SETTING THE HELIX INTO PLACE? ALSO MY HELIX IS SCORED COULD THAT CAUSE MY BELT TO SLIP?
Old Jan 10, 2006 | 12:17 PM
ncriderforks's Avatar
Yes ans Yes. You can remove the shims that seperate the 2 sheaves to give you some better take off. leave atleast one. They are different sizes. If the sheaves are worm then it can cause the belt to slip alittle. but more so will cause the shifting to change a little.
bentaxle
Jan 31, 2001 03:26 PM
00TB250
Dec 5, 2000 10:43 PM
slickster
Sep 15, 2000 09:22 PM
ScoobyDFW
May 17, 2000 04:36 PM
quadnut
34
Apr 12, 2000 05:33 PM
