700 prairie vs. sp700
The prairie 700 has a lot more power than the SP700 and it has beter handling. The SP doesn't have bad handling, it is just that the prairie has very good handling. Between these two, the prairie is more focused toward the sport end of the spectrum while the SP leans toward the utility side. They are basically built for different purposes. It is hard to say which one is the "best." It depends on what you want to use it for. Just my .02 Good luck with your decision.
according to a fellow enthusiast, the Prairie has 46hp to the Sportsman's 45, combined with the Sportsman's extra 160 pounds the Kawi is the clear winner on paper. with a solid rear axle the Kawi is also the more sporty of the two and will handle more like a sport quad with a much lower center of gravity. it's easily the Kawi if you want a sport quad with 4wd capability, however, if you want unsurpassed comfort, excellent ground clearance, work horse grunt, and a degree of sportiness, the Sportsman is the way to go.
