400 Sport rear axle question?
I am wanting to change my rear axle out on my race mod for a newer one with the breaks on the axle instead of the transmission. Can you guys tell me which models will interchange?
Thanks ALOT!
Thanks ALOT!
I did it on my 95 trailblazer. I used a hub an axle from a 98 scrambler 4X4 or newer I used the 98 because I have one an had some parts. Look at a micro fitch you need all the part except the swingarm. You will need to weld on a pin in the swingare to hold the calipare from spinning. I can get some pics if you need to for a guid. It seems to work good too use it mx racing.
you need the hub bearings, Caliper mount, The rear breakline is kind of a pain. The line that goto the newer caliper is a differnt thread then the old lines Once you have it an all the part an get it togther you will see what you need on the line. I would look on ebay to find parts.
John Boy
Jul 13, 2015 11:16 AM
