Stalls alot
Old Nov 15, 2000 | 01:51 PM
Houndog's Avatar
I'm real good about letting my Magnum warm up, but it seems to take an awful long time to get warm enough not to stall out on take off. I have to be real careful about loading and unloading so it doesn't stall out halfway up/down the ramp, besides just being annoying. Once it's warm, it couldn't be better. I bet it needs a good 7 minutes of me just sitting there. Is this normal? Thak god I live in the south with this particular bike, cuz if I was any further north, I'd be walkin'.
Houndog
Old Nov 15, 2000 | 02:30 PM
ChopperBill's Avatar
Might try running a slightly richer jet or raising the needle a notch or two.
Old Nov 15, 2000 | 04:10 PM
MagnumMudMan's Avatar
dog
What machine do you have? My 425 Magnum will idle and run smoothly after only about 30 seconds of warm up. My 325 trail boss needs approximately 2 minutes of idling before it will run right.
Old Nov 15, 2000 | 04:29 PM
Thor's Avatar
Let's start with the easiest things first.
1. Drain the carburetor
2. Adjust the idle speed
3. Adjust the low speed idle mixture
4. Adjust the half choke so that it actually works
Old Nov 16, 2000 | 12:56 AM
Houndog's Avatar
Magnummudman - I have the 325
Thor - I can drain the carb
I can adjust idle screw
How do I adjust the low speed idle mixture
How do I check the half choke settings
It cranks right up with the choke on and then after about thirty seconds, it wants to die with the half choke on. Then when you take the choke off, it sounds better, but it still wants to die unless you keep a bit of pressure on the throttle.
Could this have anything to do with the slack in the throttle cable I've heard ya'll talking about?
Houndog
Old Nov 16, 2000 | 08:33 PM
PineyKojack's Avatar
I have the same problem with my Boss. It takes a while to warm up in the cold or in damp weather. The dealer says it's common on the newer 325 engines. I also have the same prob w/ the choke...starts on full, sputters on half, then dies. I guess it's not a big deal. I found out that if you start it w/ full choke, let it get going, give it a healthy dose of gas, and you should be ok. This is strange, since my Magnum 500 takes less than a minute with only half choke in 30 degree weather...Go figure!
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
Pehter
Oct 3, 2024 11:00 PM
kbazzy
Sep 26, 2015 11:26 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
nastyblaster100
Sep 13, 2015 01:19 PM
