Choosing a Primary Clutch Spring
Old Apr 19, 2006 | 01:18 PM
badazz400's Avatar
Default Choosing a Primary Clutch Spring
Originally posted by: Mysport400
I totaly agree on the skirt breakage it will happen, It did on mine . Its a mess i was lucky didnt do any damage to the bottom half but very well could have. It seems like a hassle but rebuilding the top end back to new isnt as hard as it seems only took me about 4 hrs once the parts were in. Something to think about.
ditto on the new piston.
Old Apr 20, 2006 | 02:54 PM
cbmboy's Avatar
i agree with then all... 5 bikes is a ton... if you wanna catch him you need a full kit... Rick Ritter sells a sweet set up, it includes a new pipe, silencer, airbox mod + filter, carb kit and primary spring. Also he will talk you through anything you need help with or have a question about. He does have a setup so you can use your stock silencer so it won't get any louder. I just put this kit on my 98 400 sport and it makes a huge difference. And for what you get it doesn't really cost that much. If you are serious about waking your 400 up then give him a call...
Old Apr 22, 2006 | 11:48 AM
silent101's Avatar
Aright when saying the skirt will blow up are you guzs talking stock or modifyed because thats another thing is when you mod, things things will wear out and break faster and thats not what I want to do. Also when I said clutch spring I was going to Put a helex, weights seckondary and primary spring because I know some one who Works at an ATV shop and he knowes how to tune the cluches with a tack and all that and he said clutching is everything with these ATV's. The kit Is a little bit over my head tho, I am not looking to put that much in it. Like I said im looking for cheap upgrades. Thanks for all the feed back though I will look at the piston thing. Also I know its a common problem, anaybuddy know why my nutral light will stay on when I put it into drive?
Old Jun 8, 2021 | 10:04 PM
Jake W's Avatar
Somebody rewired your neutral safety light. I delete the reverse override and delete the neutral safety all the time. I also jump the grey white wire for the 4x4 and disconnect the throttle return safety as well. All points of failure in my opinion.
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Steeldon
Sep 9, 2015 09:38 AM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
